View IP Source Guard (IPSG) configuration on a port, with filters for IPv4 addresses.
Switch:1>show ip source verify interface gigabitEthernet 1/1
                             Source Guard Port Info
PORT                     IPSC
NUM        ENABLE        ORIGIN
1/1        true          RADIUS
All 1 out of 1 Total Num of Ip Source Guard entries displayed
The following table defines parameters for the show ip source verify interface gigabitEthernet command.
| Variable | Value |
| {slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]} | Identifies the
                                    slot and port in one of the following formats:
